An attempt was made to set a configuration without an RTM configured to handle addresses of a supported type. The MIB TEST will be rejected.
Disable the VPN route address type.
Error
An attempt was made to set a configuration without an RTM configured to handle addresses of a supported type. VRID = %p1% VPN IPv4 Address family enabled? = %p2% RTM entity index for IPv4 = %p3% VPN IPv6 address family enabled? = %p4% RTM entity index for IPv6 = %p5%
| Name | Type |
| p1 | xInt32 |
| p2 | sInt |
| p3 | xInt32 |
| p4 | sInt |
| p5 | xInt32 |
